niestety dzisiaj nie mialem dostepu do kanalu zeby sprawdzic napiecie, moze w weekend ale wtedy moze byc ciezko z czasem. po skanie byl blad zbyt niskiego cisnienia ale po skasowaniu jest ok. oto bloki:
Address 08: Auto HVAC (1K0 907 044 AC)
18:08:19 Group 002: Compressor
0.815 A Compressor Current (actual)
0.820 A Compressor Current (specified)
1000 /min Compressor Rotations
1.2 Nm Compressor Load
18:08:19 Group 003
2.8 bar Coolant Pressure
9.6 % Radiator Fan Activation (actual)
0.0 % Radiator Fan Activation (spec.)
OFF Engine Speed (increase)
18:08:19 Group 004: Temperatures
22.0°C Outside Temp. Unfiltered
22.0°C Outside Temp. Regulation
25.5°C Fresh Air Intake Temperature
81.0°C Coolant Temperature
18:08:52 Group 005: Outlet/Footwell Blower Temperature
30.0°C Left Outlet Blower Temperature
29.0°C Right Outlet Blower Temperature
30.0°C Left Footwell Blower Temp.
29.0°C Right Footwell Blower Temp.
18:08:52 Group 006
28.0°C Evaporator Temperature
27.0°C Interior Temperature
0.0 Left Sunlight Intensity (G107)
0.0 Right Sunlight Intensity (G134)
18:08:52 Group 007
Turbine Voltage (actual)
12.00 V Turbine Voltage (specified)
94.4 % Turbine Load
14.30 V Voltage (Terminal 30)
18:09:18 Group 008
14.40 V Voltage (Terminal 15)
0.0 % Dimming (Terminal 58d)
Country
18:09:18 Group 009: Rear Window Heater (Z2) && Aux. Heater
OFF Rear Window Heater (Z2 / Actual)
OFF Rear Window Heater (Z2 / Spec.)
OFF Aux. Heater Status
0.0 Aux. Heater Current
18:09:18 Group 010
OFF Aux. Heater Request
OFF Heater OFF
OFF Back-Up Lights
OFF Front Wiper
18:09:37 Group 011: Air Recirculation Flap Control Motor (V113) / Potentiometer (G143)
212.0 Current Value
212.0 Specified Value
46.0 Minimum Position (Lower Stop/Close)
212.0 Maximum Position (Upper Stop/Open)
18:09:37 Group 012: Left Temperature Flap Control Motor (V158) / Potentiometer (G220)
19.0 Current Value
20.0 Specified Value
20.0 Minimum Position (Lower Stop/Close)
227.0 Maximum Position (Upper Stop/Open)
18:09:37 Group 013: Right Temperature Flap Control Motor (V159) / Potentiometer (G221)
21.0 Current Value
22.0 Specified Value
22.0 Minimum Position (Lower Stop/Close)
229.0 Maximum Position (Upper Stop/Open)
18:09:53 Group 014: Center Flap Control Motor (V70) / Potentiometer (G112)
221.0 Current Value
222.0 Specified Value
233.0 Minimum Position (Lower Stop/Close)
26.0 Maximum Position (Upper Stop/Open)
18:09:53 Group 015: Defroster Flap Control Motor (V107) / Potentiometer (G135)
24.0 Current Value
24.0 Specified Value
226.0 Minimum Position (Lower Stop/Close)
24.0 Maximum Position (Upper Stop/Open)
18:09:53 Group 016: Air Flow Flap Control Motor (V71) / Potentiometer (G113)
26.0 Current Value
28.0 Specified Value
228.0 Minimum Position (Lower Stop/Close)
28.0 Maximum Position (Upper Stop/Open)
cos podejzanego? poza niskim cisnieniem? logi robione przy temp ustawionej na LO. jak na moje oko to cisnienie slabe. jak rusze gwaltownie i chwile pocisne to cisnienie wskakuje na 5.0 bar i tak trzyma. wyzej nie idzie
i wtedy wlasnie slychac syczenie z kratek nawiewów
