brak klimy brak błedów gaz nabity
- aprinsr
- Podziękował: 7 razy
niestety dzisiaj nie mialem dostepu do kanalu zeby sprawdzic napiecie, moze w weekend ale wtedy moze byc ciezko z czasem. po skanie byl blad zbyt niskiego cisnienia ale po skasowaniu jest ok. oto bloki:
Address 08: Auto HVAC (1K0 907 044 AC)
18:08:19 Group 002: Compressor
0.815 A Compressor Current (actual)
0.820 A Compressor Current (specified)
1000 /min Compressor Rotations
1.2 Nm Compressor Load
18:08:19 Group 003
2.8 bar Coolant Pressure
9.6 % Radiator Fan Activation (actual)
0.0 % Radiator Fan Activation (spec.)
OFF Engine Speed (increase)
18:08:19 Group 004: Temperatures
22.0°C Outside Temp. Unfiltered
22.0°C Outside Temp. Regulation
25.5°C Fresh Air Intake Temperature
81.0°C Coolant Temperature
18:08:52 Group 005: Outlet/Footwell Blower Temperature
30.0°C Left Outlet Blower Temperature
29.0°C Right Outlet Blower Temperature
30.0°C Left Footwell Blower Temp.
29.0°C Right Footwell Blower Temp.
18:08:52 Group 006
28.0°C Evaporator Temperature
27.0°C Interior Temperature
0.0 Left Sunlight Intensity (G107)
0.0 Right Sunlight Intensity (G134)
18:08:52 Group 007
Turbine Voltage (actual)
12.00 V Turbine Voltage (specified)
94.4 % Turbine Load
14.30 V Voltage (Terminal 30)
18:09:18 Group 008
14.40 V Voltage (Terminal 15)
0.0 % Dimming (Terminal 58d)
Country
18:09:18 Group 009: Rear Window Heater (Z2) && Aux. Heater
OFF Rear Window Heater (Z2 / Actual)
OFF Rear Window Heater (Z2 / Spec.)
OFF Aux. Heater Status
0.0 Aux. Heater Current
18:09:18 Group 010
OFF Aux. Heater Request
OFF Heater OFF
OFF Back-Up Lights
OFF Front Wiper
18:09:37 Group 011: Air Recirculation Flap Control Motor (V113) / Potentiometer (G143)
212.0 Current Value
212.0 Specified Value
46.0 Minimum Position (Lower Stop/Close)
212.0 Maximum Position (Upper Stop/Open)
18:09:37 Group 012: Left Temperature Flap Control Motor (V158) / Potentiometer (G220)
19.0 Current Value
20.0 Specified Value
20.0 Minimum Position (Lower Stop/Close)
227.0 Maximum Position (Upper Stop/Open)
18:09:37 Group 013: Right Temperature Flap Control Motor (V159) / Potentiometer (G221)
21.0 Current Value
22.0 Specified Value
22.0 Minimum Position (Lower Stop/Close)
229.0 Maximum Position (Upper Stop/Open)
18:09:53 Group 014: Center Flap Control Motor (V70) / Potentiometer (G112)
221.0 Current Value
222.0 Specified Value
233.0 Minimum Position (Lower Stop/Close)
26.0 Maximum Position (Upper Stop/Open)
18:09:53 Group 015: Defroster Flap Control Motor (V107) / Potentiometer (G135)
24.0 Current Value
24.0 Specified Value
226.0 Minimum Position (Lower Stop/Close)
24.0 Maximum Position (Upper Stop/Open)
18:09:53 Group 016: Air Flow Flap Control Motor (V71) / Potentiometer (G113)
26.0 Current Value
28.0 Specified Value
228.0 Minimum Position (Lower Stop/Close)
28.0 Maximum Position (Upper Stop/Open)
cos podejzanego? poza niskim cisnieniem? logi robione przy temp ustawionej na LO. jak na moje oko to cisnienie slabe. jak rusze gwaltownie i chwile pocisne to cisnienie wskakuje na 5.0 bar i tak trzyma. wyzej nie idzie
i wtedy wlasnie slychac syczenie z kratek nawiewów
18:08:19 Group 003
18:08:52 Group 006
18:08:52 Group 007
94.4 % Turbine Load
18:09:18 Group 008
Country
18:09:18 Group 010
OFF Heater OFF
OFF Back-Up Lights
OFF Front Wiper
212.0 Current Value
19.0 Current Value
21.0 Current Value
221.0 Current Value
24.0 Current Value
26.0 Current Value
- Auto:: Touran 2.0
- Imię:: Tymek
Panowie u mnie to samo. Klima nabita niestety chłodzenia brak, na VAGu zero błędów.
Moja w sumie wina po co pojechałem nabić klimę, skoro włączenie i wyłączenie przycisku econ zawsze powodowało chwilową zmianę obrotów no i na FIS spalanie rosło. Tym czasem nic to nie zmienia
Czytałem forum i problemami podobno może być cewa,wiatrak spreżąrka.
Czy ktoś kto rozwiązał problem? Może jakieś wytyczne?
Np gdzie spojrzeć co zobaczyć, aby zdiagnozować czy jest to wentylator czy też sprężarka?
Ewentualnie co sprawdzić w blokach pomiarowych?
Może to śmieszne ale gdzie w ogóle jest ta sprężarka i wentylatory które mogą powodować ten błąd?
Niestety z kasą krucho i do mechanika się raczej nie wybiorę
Z góry dzięki za pomoc.
znalazłem taki błąd
Adres 08: Klimatyzacja Plik etykiet: 1K0-907-044.lbl
Oznaczenie elementu: 1K0 907 044 AC
Komponent: ClimatronicPQ35 066 0404
VCID: 68D5C3315B2DAF58895
Znaleziono 1 błąd:
00898 - Sterowanie sprężarką klimatyzacji
010 - Przerwa / zwarcie z plusem - Sporadyczny
napięcie do sprężarki dochodzi ale nie wiem jakie. Wentylatory po włączeniu klimy nie ruszają.
z góry dziękuję za pomoc
Znaleziono 1 błąd:
- aprinsr
dobra, zrobiło się troche cieplej i po dotknieciu 2 rurek jedna była troche chlodniejsza od drugiej, różnica byla wyczuwalna ale nie kolosalna. po przeskanowaniu wywaliło mi oto takie błędy:
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
000 - - - Intermittent
00229 - Refrigerant Pressure
klima nabijana niecały rok temu przy wymianie chłodnicy - już uciekło?
dzisiaj nawet spalanie na postoju wskoczyło na 0,7l/h - łudzę się że sprężara sprawna
wentylatory sie nie włączaja - ale podczas testu chodzą tak że aż "budą trzęsą"
2 Faults Found:
- aprinsr
wracając do napięcia. żeby je sprawdzic klima zapewne musi być nabita?Rafik pisze:aprinsr, żeby wykluczyć presostat wejdz w bloki pomiarowe w sterowniku klimy , sprawdz ciśnienia, a jak to nic nie da to przy sprężarce powinno być 12V co załączy cewkę sprężarki ( sprawdz miernikiem przy sprężarce ):D
[ Dodano: Sro Cze 12, 2013 23:11 ]
napiecie na sprezarce na poczatku skacze do 20 nastepnie spada na 3,5v i tak juz sie utrzymuje
